08-06-2015 07:39 PM
Can anybody explain to me the benefits / difference between using a ballasted mount vs a standard on a roof with a 15% pitch?
I'm talking about these two IronRidge products: IronRidge standard rail vs IronRidge Ballasted Roof Mount
Thanks!
HB
I'm talking about these IronRidge Ballasted Roof Mount and IronRidge standard rail
Answered! Go to Answer.
08-07-2015 09:16 AM
The ballasted roof mount is best for roof's with a 15% pitch
08-10-2015 08:22 AM
08-14-2015 12:45 PM
You know I was told the opposite by my installer. i'm now thoroughly confused.
Can somebody point me to an article with manufacturer details?
Thanks!
Mick
09-10-2015 09:48 AM - edited 09-10-2015 09:49 AM
When it comes time to choose a flat roof solution, the IronRidge ballasted roof mount system is the best & easy choice.
Composed of only three primary components, this intuitive system is easy to learn and even faster to install.
Described by a customer as “the most rugged ballasted system” he’s ever used, the structural steel framework is built to last and backed by an industry-leading 20-year warranty. Even with the heavy-duty construction, the IronRidge ballasted system is light on the roof. Through collaboration with one of the top wind tunnel testing laboratories, engineers have worked hard to develop a system that minimizes the amount of ballast required. In addition, an extruded EPDM rubber footing is available to help protect and maintain your roof’s warranty.
Modular ballasted system works with any size array and easily configures to avoid roof obstacles such as HVAC units or skylights. Since commercial rooftops are never completely flat, the ballasted solution was designed specifically with uneven surfaces in mind. The patent-pending pivoting mounting plate delivers ultimate directional flexibility allowing the system to automatically adjust to the contours of the roof.
09-10-2015 09:52 AM
Here's a great video I found that details the use cases for Ballasted.
https://youtu.be/O5SZJwEx_vU?list=UUklxreLzKrjpU62riCmo4zw
09-10-2015 10:02 AM
@MickS I totally feel ya.
I'm running into the same issues with my installer. I finally did my own research and found a ton of information on this site. I've attached a data sheet for you as well.
This diagram was super helpful to explain to my installer:
09-10-2015 12:54 PM
WE are glad you are getting the response you need. Here is some more information we think will be helpful.
09-21-2015 01:51 AM
Great Video!
Thanks for sharing!
