09-28-2015 01:30 PM
In just a few short years, the Internet has started to add connectivity to everything from home audio to even garage doors. Known as the ‘Internet of Things’ this growth in technology is now leading to affordable and easy-to-use systems, apps, and hardware for automating your entire home.
If you own a LiftMaster garage door opener, you may be familiar with the MyQ system that uses an app and Internet connectivity to allow you to open and close your garage door from anywhere!
However, that’s just one thing that home automation systems can do. In fact, they can also be used to control lighting, heating, security, and you may even be able to control all your appliances over the Internet one day too.
If you’ve always wanted to be able to open your garage door with your phone, adjust your thermostat without leaving your bed, or you’re simply curious about the Internet of Things you should check out these home automation blogs below!
Answered! Go to Answer.
09-28-2015 01:38 PM
