Accepted Answer
Apply Fix for Degrees Setting on Haven Thermostat
[ Edited ]
Hello Ecohausers,
We've discovered there is a slight bug in the Celcius/Farenheit configuration in the Haven app.
NOTE:  If you are configured to be in one or the other and do not switch views at all then you should not have any issues.
IF you are in a household that requires there to be a toggle for Farenheit and Celcius. Please apply the following fix to your mobile application.
1. Open the Haven App from your iOS or Android device
2. Navigate to Settings
3. Under Preferences > Degrees > Toggle ON the Setting:  O Both F / C
4. Select SYNC with Haven.
This will allow any user who passes to toggle on either / or Farenheit/Celcius temperature. The fix should be applied immediately.
Please contact us on Twitter/Facebook or mention @Ecohaus in your post if you have any questions.
Best,
EH Support
Professor
Re: Apply Fix for Degrees Setting on Haven Thermostat
Oh, thank goodness for this!  My partner and I have a little antagonistic game we play with the thermostat.  Now there will be peace in our home.  Phew!
Keep on innovating Ecohaus!
Cheers!
OK . Pas de problème. Appuyez sur le bouton rouge
Are you all set with this resolved?
