This list is dedicated to hardware controllers, which are devices designed to support one or more home automation protocols, with or without expansion modules. In order to make it on the list, the hardware should still be available for purchase.
This list is divided in 2 categories:
  • Intelligent Controllers, which support some sort of programming language, and can respond to certain conditions and home automation commands.
  • Dumb controllers are devices which don't support any logic, but can be programmed to execute some basic tasks (i.e. scheduled lights on/off) without depending on a PC.
A home automation hardware controller does not require a permanent PC link.
Keep in mind that until we set up the matrix overview, we only want to list the basic protocols/interfaces the device has, or the list would grow too large considering most of these controllers can do much more.
ADI Ocelot (X10-PLC,I/O,IR)
ADI Leopard II (X10-PLC,I/O,IR)
JDS Stargate (X10-PLC,I/O,IR)
HAI Omni II (X10-PLC,UPB,I/O,ALC,IR)
Universal Devices ISY-26 (Insteon)
Elk M1 Gold (X-10,UPB,Z-Wave,Insteon,I/O)
Elk M1 EZ8 (X-10,UPB,Z-Wave,Insteon,I/O)
HomeVision (X10-PLC,UPB,IR)
HomeVision Pro (X10-PLC,UPB,IR)
'Dumb' Controllers
X10 CM11A (X10-PLC)
X10 CM15A (X10-PLC,X10-RF)
SmartHome USB PowerLinc 1132CU (X10-PLC)
Hardware Controllers for Home Automation
by Community Manager on ‎12-20-2013 10:29 AM (1,448 Views)
